April 15, 20251 yr Hi all I have an old cottage and have removed a false plaster board ceiling to the hallway exposing the original beams which I would like to keep . Unfortunately, when the house was modernised much of the cabling was hidden behind the false ceiling and are now exposed. I want to re route the cables and box in along the top of one of the walls. Do the Twin & Earth cables need to be fully separated with clips to ensure they don't overheat or can they be grouped together at all please? Cables to run: 1 x 6mm T&E (cooker) 2 x 2.5mm T&E 3 x 4mm T&E 2 x 6mm single core cables Many thanks
April 15, 20251 yr This is some info on grouping cables and other related stuff that might be of use. https://www.tlc-direct.co.uk/Book/4.3.5.htm
April 15, 20251 yr And bear in mind the fire implications, cables should be supported with metal clips so in the event of a fire they don't hang down endangering fire fighters.
