Sealo0 Posted March 10, 2025 Author Posted March 10, 2025 (edited) I think might have found the answer! as this is a two way circuit from V pro specs ” V-Pro Smart rotary dimmers cannot be used in conjunction with conventional switches in a 2-way circuit. Does this mean that V pro cannot be used in a two way circuits? That’s nuts mike Ps I have asked Varipro what they think? Mike Edited March 10, 2025 by Sealo0 Ps added
ProDave Posted March 10, 2025 Posted March 10, 2025 I think the more important question might be what is above the ceiling? What is making that one of a set of identical lamp holders get hotter than the rest? Is something blocking the ventilation holes? Is there insulation there? Is there a hot pipe running through that section of ceiling meaning it is a much warmer space? etc etc. 1
Sealo0 Posted March 10, 2025 Author Posted March 10, 2025 17 minutes ago, ProDave said: I think the more important question might be what is above the ceiling? What is making that one of a set of identical lamp holders get hotter than the rest? Is something blocking the ventilation holes? Is there insulation there? Is there a hot pipe running through that section of ceiling meaning it is a much warmer space? etc etc. Hi Dave no insulation no pipes , upper floor is a bedroom HTH Mike
