Nickfromwales Posted March 6, 2025 Posted March 6, 2025 24 minutes ago, Barry1965 said: free standing units with a plinth or without? With gaps at the rear or without? Most don't like to install heated floors under the plinth space where foodstuff is stored, generally frowned upon in anything other than a Passiv Haus where the slab temps are 'almost cool' anyway.
Barry1965 Posted March 6, 2025 Author Posted March 6, 2025 No plinths and food will be stored elsewhere, so there shouldn't be an issue heating these areas. 1
SteamyTea Posted March 6, 2025 Posted March 6, 2025 As it is a kitchen, I assume it is only used, mainly, for cooking/meal times. If this is right, the temperature will fluctuate wildly. So UFH may not be the best heating solution. Plinth heaters may be a good match as they can heat the air, which the hob extractor is removing, fairly rapidly. The output can be matched to the extractor air flow. They can also be put on timers/thermostats to keep the overall room temperature within acceptable limits, even cooling if needed. Noise should not be a problem as kitchens are noisy anyway.
Barry1965 Posted March 7, 2025 Author Posted March 7, 2025 Thanks for the plinths heaters idea. These look to be cheap and effective https://kitchenheaters.co.uk/product-category/heat-pumps/ but does anyone have any experience of these or other models? Is the noise excessive? I can only find a couple of videos online that suggest they might be noisy...
Super_Paulie Posted March 7, 2025 Posted March 7, 2025 I have 2x SS5 and they are borderline silent on "normal" mode. I also got a SS7 which was noisy for me (tinnitus) so i replaced it with the SS5. Id imagine over time they will get noisy as they are at floor level and its basically a daft little fan which would dry out, get dirty etc but its nothing a bit of a dismantle and clean wouldnt sort out.
Nickfromwales Posted March 8, 2025 Posted March 8, 2025 Yup. Quiet afaic, but defo need a good clean before each winter so they run as quietly and efficiently as possible.
