NewbieJ Posted February 27, 2025 Posted February 27, 2025 Hi All I have recently moved in to a new build flat that has a Nuaire MVHR installed, however, I am not sure it is working as it should be at the moment. I joined the forum and hoping people here would be able to advise if the system I have is working correctly.
JohnMo Posted February 28, 2025 Posted February 28, 2025 Hi welcome, you may be best to start a topic in the correct area, and explain why you think you have an issue.
jack Posted February 28, 2025 Posted February 28, 2025 9 hours ago, NewbieJ said: Hi All I have recently moved in to a new build flat that has a Nuaire MVHR installed, however, I am not sure it is working as it should be at the moment. I joined the forum and hoping people here would be able to advise if the system I have is working correctly. Welcome! Post any questions or concerns over in the ASHP sub-forum and I'm sure you'll get the help you need.
JohnMo Posted February 28, 2025 Posted February 28, 2025 14 minutes ago, jack said: Welcome! Post any questions or concerns over in the ASHP sub-forum and I'm sure you'll get the help you need. Or even the MVHR sub forum?
jack Posted February 28, 2025 Posted February 28, 2025 Ah yes, the MVHR sub-forum. I should never do anything on the mobile.
