Can anyone tell me what this is called?
It seems the parts (seems plastic?) at the size of the roof are missing and it is leaking a bit (the chimney side, I can see the sky inside), it is something I can fix and what is it called?
Also seems there is a tile on the top of the roof missing but i did not see a leakage, is it something i should repair asap?
thanks
55 minutes ago, Mr Punter said:
That is a plastic dry verge and concrete ridge tiles.  The biggest issue is safe access.
The concrete one must be down by someone professorial. I should be able to access the black plastic one at side by using leaders, it is something nails used to connect with the roof?
40 minutes ago, twice round the block said:
Use your home insurance and let them send a roofing contractor round.
I always have one question, if there is something existing in the house before i bought the insurance, for example, some issues existing long time but i never noticed until recently, will the insurance company will deal with it?
You are mistaken.
These issues probably happened AFTER you took out the insurance. I am sure you just have very bad memory......
