lord mud of the flyes Posted January 13 Posted January 13 Hell there Would like to make a bar like this so it looks as neat and cheap as possible Thinking of using old pallets for the side of the bar. But not sure how to get the nails out of the pallets so it dose not split the timber, and what paint I should use? What kind of wood and paint do you think I should use for the work top? And same question again for the skirting boards? I all ready have some old fence post wood that I am considering using for the frame. But I am unsure of how to attach all of the above to the frame as nails and screws would look so tack? Any advice please? Thanks
Redbeard Posted January 13 Posted January 13 (edited) @Onoff, excellent. Seems to me, OP, that you'll only maybe need 1 row of 'visible' fixings in the middle of the height of the pallet-wood, since the top and bottom 'skirtings' can trap the rest. I would use oval nails, punch below the surface of the wood and use coloured filler to hide the punch-marks. The likely 'mottling' of the pallet-wood will probably help to hide them too. Edit: Make sure to 'acclimatise' the pallet-wood to its intended environment before you commit to any fixings. Edited January 13 by Redbeard
ToughButterCup Posted January 13 Posted January 13 (edited) 2 hours ago, lord mud of the flyes said: ... What kind of wood and paint do you think I should use for the work top? [...] the skirting boards? I all ready have some old fence post wood that I am considering using for the frame. But I am unsure of how to attach all of the above to the frame as nails and screws would look so tack? ... What you have the same theres your answer to the two points above who (other than you) is going to notice them when they are in the wood? Edited January 13 by ToughButterCup
lord mud of the flyes Posted January 15 Author Posted January 15 On 13/01/2025 at 08:06, Onoff said: First make a pallet buster: I looked up pallet buster and found one like this Roughneck Pallet Buster Demolition Bar 43" - Screwfix 32 quid, but since as it will not be used much, do you think something cheaper like this would do? Roughneck "T" Type Wrecking Bar 24" (600mm) | Toolstation
lord mud of the flyes Posted January 15 Author Posted January 15 On 13/01/2025 at 09:05, Onoff said: Let's not overthink this, a few beers in etc: It dose look rather tact to me with resects!
lord mud of the flyes Posted January 15 Author Posted January 15 (edited) On 13/01/2025 at 09:49, ToughButterCup said: who (other than you) is going to notice them when they are in the wood? Quite a lot of people if it roves to be a sucsess in the end Edited January 15 by lord mud of the flyes
Onoff Posted January 15 Posted January 15 4 hours ago, lord mud of the flyes said: It dose look rather tact to me with resects! Translation please. Check out YouTube for how to dismantle pallets. Generally involves a bfo lump hammer and block of wood to start with.
