Canski Posted January 11, 2025 Posted January 11, 2025 Hi all. I’m after some help. My Daikin Altherma has been working fine until yesterday but now I have no heat. When the unit is switched on the circulator runs until about 30 l/min flow then after about 90 seconds it switches off. No fault codes are showing. I’ve tried an hard reboot as well as a full reset on the controller but no luck. Any ideas what to do ?
Bramco Posted January 11, 2025 Posted January 11, 2025 Not sure if this is fixed already but try posting on the open energy monitor forum - there's a lot of discussion about Daikin's on there. More about getting them set up properly but there's a lot of experience. 1
Canski Posted January 14, 2025 Author Posted January 14, 2025 On 11/01/2025 at 18:08, Bramco said: Not sure if this is fixed already but try posting on the open energy monitor forum - there's a lot of discussion about Daikin's on there. More about getting them set up properly but there's a lot of experience. I’ve only just seen this but thank you. Daikin can’t work out the problem remotely so are sending an engineer to meet the installer on Thursday.
Canski Posted January 18, 2025 Author Posted January 18, 2025 Update …. the heat pump burst back into life on Wednesday night all by itself. We informed daikin and they cancelled the call out. It’s a bit of a bugger really as I still don’t know what the issue was. I feel that it is connected to the cold weather but I won’t know until the next cold spell. Luckily I was away for the last breakdown.
