Need to replace a cracked tile on a tanked shower wall. Is it possible to remove the tile without damaging the tanking underneath? If not what’s the best way to repair the wall to make it waterproof again?
thanks
Not sure about how to remove the tile... Multi cutter or angle grinder then a chisel from the inside out?  not all showers are on tanked walls IIRC, albeit it not exactly best practise. I've stipulated it on our bathrooms before, but if you have moisture rates PB I'm sure some shrug it off?
I've also always used grout spray to seal the ggrout for belt and braces.
The above being me not being an expert!!
Edited by Andehh
