blauberg KOMFORT-EC-LB-400-S25
  • sonicboom changed the title to blauberg KOMFORT-EC-LB-400-S25
On paper looks fine, 5 year warranty - but
How much are filters to replace? You need to look things like that.
Do they require an approved contractor install and commission to get the 5 year warranty?
Is there UK technical support?
Do need modbus and WiFi connected? My opinion no, install, commission, forget (except servicing).
Do you need CO2 response? Not really.
I would look a Titon also, UK made, UK technical support, good solid unit.
Blauberg are well known, but don't have any MVHR units in the Passivhaus database, which lists models independently tested to more accurate standards than those required in the UK and those used by manufacturers. So it's difficult to know how good it is.
https://database.passivehouse.com/en/components/list/ventilation_small
Edited by Mike
