Extra ducts through walls?
Has anyone ever put in extra ducts though rising walls for potential future cables/pipes?  I don't mean lengths of ducting, just say old pieces of 110mm drainage pipe though the wall and then blocked  and capped off, so you have an entrance point below ground if you ever required it?  I'm just trying to future proof anything I can before the first course of ICF gets concrete poured into it.
If anyone has, at what level did you put them? I was originally thinking of under the B&B floor level but that is almost pointless and a lot of effort to get a pipe or cable through?
Can't do any harm, although it's not the end of the world if you need to core through the ICF at a later date. We have needed to core twice already? first for extra steel I beam for 1st floor and 2nd for cables through to snug.
Which ICF did you choose?
Edited by Alexphd1
