Identify this please
Pocster
The stupidly over priced parts arrived !
Strangely enough they are a few mm different to my attempted effort . So the waterless trap , rubber washer , fitting itself all just a tad smaller than the bits I tried to get - so not compatible . I assume this is deliberate to stop people like me !
Anyway - will attempt my double trap thing tomorrow.
This turned into a pita .
Trying to get both traps to run towards the wall and into a tee . Just wasn’t going to happen . Not enough space .
So took the not so dignified approach ( open to ridicule for sure ) and made the traps run towards me - easier for sure .
HepvO can be installed vertically or horizontally, or any angle in-between. When installing horizontally a minimum allowable slope of 1/8” (3.175mm) per foot (30.48cm) must be maintained to ensure good drainage. This can be achieved by using the HepvO Angled Adapter supplied in the HepvO kit.
3 minutes ago, joe90 said:
Don’t the traps have to be vertical? (Just asking as I know nothing about them and difficult to see from that pic which way is up).
Don’t think so . Before my issues they were horizontal ( with a slight fall ) . That worked fine for 4 yrs . Also 1 set were supplied with the mvhr and the 90 goes straight to the drain outlet - so assumption is ( as supplied by vent axia ) that it’s ok .
Edited by Pocster
