deuce22 Posted November 28, 2024 Share Posted November 28, 2024 Hi. I am looking for some clarification. Does acoustic insulation have different properties over thermal insulation. I’ve been told, that for soundproofing, it is all about density. If an insulation that is marketed as accoustic, weighs 10kg m3 and an insulation that is marketed as thermal, weighs 15kg m3, will the thermal insulation provide better soundproofing? Thanks. Link to comment Share on other sites More sharing options...
JohnMo Posted November 28, 2024 Share Posted November 28, 2024 Main difference is stiffness, but that is so it doesn't slump after installation. Most acoustic insulation is in walls. The thermal insulation for lofts is really soft and would slump over time. Link to comment Share on other sites More sharing options...
deuce22 Posted November 28, 2024 Author Share Posted November 28, 2024 So would a heavier insulation, whether it was marketed for thermal or accoustic, have better sound proofing properties? The plasterer has just told me that he uses standard boards, but doubles them up, rather than using accoustic boards. The double standard board gives better density and is also cheaper. I just want to understand if density is the main requirment for sound proofing. Thanks. Link to comment Share on other sites More sharing options...
