Heat Pump setting with buffer tank
Wingover
On 01/11/2024 at 11:10, IanR said:
Thermocline/stratification is a robust phenomena that does not require balanced flow rates
4 hours ago, IanR said:
If after multiple readings, at different times, you are still seeing a similar result are you could try to slow the emitter pump down
Thought you said balance wasn't needed? Looks like classic mixing and distortion going on.
The Lazer may not be accurate on different surfaces but is repeatably on the same surface as a comparison. The two degs makes a decent difference in running costs
I'm going to ignore your comments now, no idea why you choose to be argumentative, some of your input is of value.
The ASHP will be on and off, the emitters are more constant. They are not balanced.
