Creakyoldhouse Posted October 16, 2024 Posted October 16, 2024 Hello, I have two GRP flat roofs that are failing due to poor installation and need to be replaced, including the build up. They are each about 25m2 and have a large roof lantern in the middle. The lanterns are wood and a pain to remove (impossible without damage). I am concerned about using GRP again given our bad experience so I want to look at other options too, such as EDPM. Would it be impossible to re-roof in EDPM without removing the lanterns? They sit on an upstand so it wouldn't be possible to bring the EDPM up over the top with the lanterns still in place. Any thoughts welcome please. Thanks
scottishjohn Posted October 16, 2024 Posted October 16, 2024 (edited) as you stated the problem with the GRP was installation --not the product itself with grp roofing it is essential that the boards under them are replaced at same time If these roofs were a repair of exsisting other roof my guess is they cut corners the prodcut is fine as for a rubber roof i have a friend who has a hotel with rubber roofing ,or had the crows would take things up on there and peck at them and made holes in the membrane it could also be they did not allow for expansion a good roofer will know how big it can be before it needs expansion flashings note the expansion joint on my balcony and lead flashings in the stone work that come down over the grp upstand flashings at the edges Edited October 16, 2024 by scottishjohn
Creakyoldhouse Posted October 16, 2024 Author Posted October 16, 2024 That’s interesting. Thanks for sharing your experience. I think I will speak to some local GRP installers to see what is possible.
Conor Posted October 16, 2024 Posted October 16, 2024 show us some photos. I've installed two DIY GRP roofs and I've never had an issue. Might be able to sand it down and put another layer on.
Creakyoldhouse Posted October 17, 2024 Author Posted October 17, 2024 Hi Conor, I can’t show photos right now but the GRP is flaking and large cracks have appeared over board joins. The roofs are very noisy in the sun and make loud banging noises when temps drop at night. No firrings were used at joist level and the roofs have standing water all the time so need a proper fall and we have no height available to work on top.
scottishjohn Posted October 17, 2024 Posted October 17, 2024 16 minutes ago, Creakyoldhouse said: Hi Conor, I can’t show photos right now but the GRP is flaking and large cracks have appeared over board joins. The roofs are very noisy in the sun and make loud banging noises when temps drop at night. No firrings were used at joist level and the roofs have standing water all the time so need a proper fall and we have no height available to work on top. sounds like rip it all off and start again I there somewhere the water goes off the roof into a drain pipe even if its flat ? if its not a roof you ever walk on every day and its very flat you could cover it with a layer of chips when its done .that will keep water on tthere to ceratin level and stop it getting too hot
Creakyoldhouse Posted October 17, 2024 Author Posted October 17, 2024 Thanks Scottish John. There is a drainage outlet but the fall is rubbish so water doesn't exit unless at a very high level. The roof is only walked on for maintenance so I will look into adding a layer of chips, thanks!
scottishjohn Posted October 17, 2024 Posted October 17, 2024 (edited) 1 minute ago, Creakyoldhouse said: Thanks Scottish John. There is a drainage outlet but the fall is rubbish so water doesn't exit unless at a very high level. The roof is only walked on for maintenance so I will look into adding a layer of chips, thanks! it was very common when everyone used roofing felt as summer temps would cause damage Edited October 17, 2024 by scottishjohn
