Mezzanine floor (light domestic use)
195 x 45 C16 joists on 600 mm centres spanning 3 metres.
120 x 28 mm tongue and groove pine/spruce floorboards.
I would like to secret fix (screw through tongue) these boards AND glue the to the joists to avoid squeaks (caused by screwing through the tongue not being enough to pull the boards tight against the joist if the joist isn't perfectly level or the boards are not perfectly matched in thickness)
Which glue and screw?
"Yellow glue" (aliphatic resin) or "Bubble glue" (PU)?
https://www.titebond.lt/titebond-original-wood-glue/
https://www.titebond.lt/titebond-polyurethane-glue/
Which screw? (note - softwood not ply)
