What were the outside and inside temps?
Not sure that ~16°C in a corner is that bad, if it's close to freezing outside. What's under the door threshold? Is it block & beam on a strip foundation, similar, or an insulated raft?
A quick calc has the inside face of the door at 16.7°C with an outside temp of 0°C and inside temp of 21°C for a door frame with a 0.86 Uf value. With a little thermal bridging that could easily drop lower.
Edited by IanR
If the door is sitting on a concrete beam/slab that's bridging from the outside to the inside, that easily explains the heat loss at the bottom. Can you remember the buildup?
