Hi,
Just starting to install my chimney, Isokern pumice liner.
I have spoke to Isokern but no joy...
Basically we have the 45° T section going into the house and upwards. But what do I do with the bit below on the T ? Does it need a plug? Surely it's not left open?
I know I need a soot door to sweep/access which I've accounted for but I can't think this hole at the bottom stays open?! Ta
4 hours ago, dpmiller said:
there's a base fitting with a drain hole in our Swift Air setup, I think Isokern should be the same? "Base stone with drain" is the item.
I need the pumice liner though, not the ceramic
I need a tee cap but can find kne anywhere! Maybe I can adapt an aluminium one?
