markharro Posted September 11 Share Posted September 11 Hi Can anyone supply a link for what I am describing - basically a media socket dongle that will accept a PoE wire and output as a USB C female socket? thanks Link to comment Share on other sites More sharing options...
IanR Posted September 11 Share Posted September 11 35 minutes ago, markharro said: a media socket dongle that will accept a PoE wire and output as a USB C female socket? thanks How about a wired RJ45 female face plate into which you insert this: https://www.amazon.co.uk/Mygatti-RJ45-Converter-Connection-Compatible-gray/dp/B0CXSSJJK8?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A1AIM872KBP6AR&th=1 Link to comment Share on other sites More sharing options...
PNAmble Posted September 11 Share Posted September 11 https://directnine.uk/products/poe-texas-gigabit-poe-splitter-inwall-usb-charging-port-fast-5v-usb-charging-and-rj45-power-over-ethernet-output-for-wifi-internet-router-camera-phone-network?gad_source=1&gbraid=0AAAAAp5BeSog5eB1kb7ZriLjL380rXEor&gclid=CjwKCAjw_4S3BhAAEiwA_64YhkP5X_uZ9rZxzk71r1BQh_tZbIibveTOQIf-5tX3dmE7VD40d2AYSxoCOmcQAvD_BwE Would this work ? not a standard size though.. Link to comment Share on other sites More sharing options...
garrymartin Posted September 11 Share Posted September 11 3 minutes ago, IanR said: How about a wired RJ45 female face plate into which you insert this: https://www.amazon.co.uk/Mygatti-RJ45-Converter-Connection-Compatible-gray/dp/B0CXSSJJK8?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=A1AIM872KBP6AR&th=1 Wrong technology. That won't work to provide power I'm afraid. @markharro Can I ask what it's to be used for? That might help narrow down the right solution/technology. Link to comment Share on other sites More sharing options...
markharro Posted September 11 Author Share Posted September 11 Thanks - @garrymartin the idea is to power an always on ipad or similar tablet to be used for smarthome controlling etc. Then I also have a couple of low power temp sensors and reader display which are powered via USB C Link to comment Share on other sites More sharing options...
garrymartin Posted September 11 Share Posted September 11 (edited) 11 minutes ago, markharro said: Thanks - @garrymartin the idea is to power an always on ipad or similar tablet to be used for smarthome controlling etc. Then I also have a couple of low power temp sensors and reader display which are powered via USB C Gotcha. Let me find something appropriate Edited September 11 by garrymartin Linked to a 220V-240V version rather than PoE Link to comment Share on other sites More sharing options...
garrymartin Posted September 11 Share Posted September 11 If you want a really slick, integrated solution, you could look at something like https://displine.uk/products/displine-poe-converter-22w But if you're happy to have an adapter in the wall, you could use something as simple as this https://www.amazon.co.uk/DSLRKIT-Active-Splitter-Female-802-3af/dp/B073P7J1KR/ with an appropriate cable of your choice. It doesn't need to be a higher-powered quick charge (PD or similar) as your tablet will likely be permanently connected. If you're trying to do something without spending a fortune, and have or know someone with a 3D printer, there are also lots of 3D models for tablet wall holders on various sites. Link to comment Share on other sites More sharing options...
markharro Posted September 11 Author Share Posted September 11 4 hours ago, garrymartin said: If you want a really slick, integrated solution, you could look at something like https://displine.uk/products/displine-poe-converter-22w Thanks yes this is the sort of thing. Not clear however how it would fit inside a standard UK wiring box but why so expensive! I think this would power an Apple Homepod mini though so thats interesting. Link to comment Share on other sites More sharing options...
garrymartin Posted September 11 Share Posted September 11 46 minutes ago, markharro said: Thanks yes this is the sort of thing. Not clear however how it would fit inside a standard UK wiring box but why so expensive! Fits inside a 60mm Euro box, but no idea why they are so expensive. Link to comment Share on other sites More sharing options...
zzPaulzz Posted September 11 Share Posted September 11 (edited) 5 hours ago, garrymartin said: If you want a really slick, integrated solution, you could look at something like https://displine.uk/products/displine-poe-converter-22w But if you're happy to have an adapter in the wall, you could use something as simple as this https://www.amazon.co.uk/DSLRKIT-Active-Splitter-Female-802-3af/dp/B073P7J1KR/ with an appropriate cable of your choice. It doesn't need to be a higher-powered quick charge (PD or similar) as your tablet will likely be permanently connected. If you're trying to do something without spending a fortune, and have or know someone with a 3D printer, there are also lots of 3D models for tablet wall holders on various sites. Cheaper here: £54. Probably shipping and tax on top. Same product though as far as I can tell. https://www.aliexpress.com/item/1005006216842254.html?spm=a2g0o.productlist.main.49.706fa3Spa3SpBs&algo_pvid=99a4c398-362c-4cad-8d1b-eba9e5600680&algo_exp_id=99a4c398-362c-4cad-8d1b-eba9e5600680-24&pdp_npi=4%40dis!GBP!106.78!53.39!!!135.75!67.88!%40210387dd17260731937254697eddc0!12000036322462749!sea!UK!889673203!X&curPageLogUid=KRqsJZNZNPs7&utparam-url=scene%3Asearch|query_from%3A There's a lot of UK companies reselling stuff that we can get direct from AliExpress. I guess they offer a degree of quality assurance and convenience but sometimes the mark-up is fierce. Edited September 11 by zzPaulzz 1 Link to comment Share on other sites More sharing options...
