Kuro507 Posted September 6, 2024 Posted September 6, 2024 The house we are purchasing has a borehole, which we have finaly located.😀 I will get a local Company to come and survey it, to ensure its still fit for purpose. However, I would like to understand for myself how these systems are supposed to work and how they should be plumbed together.  There is a currently a Grundfoss 170lt accumulator, Ph tank with backflow, all supplied by a Lowara 0.75kW pump. A water quality test was done and recommendations were to change the Ph from 6.8 (I suspect the Ph unit needs simply needs recharging), to add a filter unit and UV.  What order should these be connected together, starting form the incoming water from the borehole/pump?  For things like washing the cars, watering the garden etc. is there any sense in taking a feed to a garden tap from further back in the connected systems? Therefore not wasting money filtering or cleaning water thats not for human consumption?  I'm likely to undertake most day to day maintenance myself, so understanding how it all works, getting spare parts ready is going to help.  Thanks in advance for advide and guidance, its a steep learning curve! Â
Kelvin Posted September 6, 2024 Posted September 6, 2024 I have a schematic of mine. I’ll post it up later. 1
JohnMo Posted September 6, 2024 Posted September 6, 2024 Don't arse about, have all water filtered. Get a company to install, so you are covered for wholesome water. They will disinfect as required also.  If your water isn't pH neutral the last thing you want is to spray that all over your car or plants.  Servicing, day to day, there is none. We have just had an annual service done, everything reset as required media topped up, filters replaced etc. £160 incl. VAT.  Filter changes (10, 5 micron and UV) are an annual task unless water source is really mucky. Last year watering 800m of banking (2 hose pipes for around 2 hrs continuously) every other day throughout summer added an extra 10 and 5 micron filter change, so about £10. 1
Kelvin Posted September 6, 2024 Posted September 6, 2024 @JohnMo out of interest, who maintains your installation?Â
JohnMo Posted September 6, 2024 Posted September 6, 2024 2 hours ago, Kelvin said: @JohnMo out of interest, who maintains your installation? GRC Aquatech from Insch in AberdeenshireÂ
sharpener Posted October 8, 2024 Posted October 8, 2024 (edited) On 06/09/2024 at 13:33, Kuro507 said: There is a currently a Grundfoss 170lt accumulator, Ph tank with backflow, all supplied by a Lowara 0.75kW pump. A water quality test was done and recommendations were to change the Ph from 6.8 (I suspect the Ph unit needs simply needs recharging), to add a filter unit and UV.  What order should these be connected together, starting form the incoming water from the borehole/pump?  We have a 10in BB 5um wound string filter, a 20 in BB 1 um activated charcoal filter and a UV steriliser in that order. You want all this downstream of the pH tank. GAPS Water or Wrekin Water for all the above.  On 06/09/2024 at 13:33, Kuro507 said: For things like washing the cars, watering the garden etc. is there any sense in taking a feed to a garden tap from further back in the connected systems? Therefore not wasting money filtering or cleaning water thats not for human consumption?  Don't often disagree with @JohnMo but we find this useful. pH 6.8 is not badly acidic, limit for human consumption is 6.5, our rainwater is 5.5 and it hasn't eaten our cars yet!  On 06/09/2024 at 15:55, JohnMo said: We have just had an annual service done, everything reset as required media topped up, filters replaced etc. £160 incl. VAT.  Brilliant! If I could get it done for that in S Devon I would go for it. Unfortunately I have not found a reliable competent firm in 17 years despite various recommendations. Anyone got any suggestions?   Edited October 8, 2024 by sharpener
