Hannah82w Posted September 3, 2024 Share Posted September 3, 2024 What can be done with the offcuts of PIR board that just can't be used anywhere else in the build? Can it be recycled in any way? If it has to go to the tip, does it count as DIY waste (usually plasterboard, rubble etc...PIR not listed by our council) or does it just go in general waste at the tip or a skip? Would rather not just put in landfill if possible! Link to comment Share on other sites More sharing options...
Onoff Posted September 3, 2024 Share Posted September 3, 2024 Gumtree, FB Marketplace etc. Link to comment Share on other sites More sharing options...
MikeGrahamT21 Posted September 3, 2024 Share Posted September 3, 2024 26 minutes ago, Hannah82w said: What can be done with the offcuts of PIR board that just can't be used anywhere else in the build? Can it be recycled in any way? If it has to go to the tip, does it count as DIY waste (usually plasterboard, rubble etc...PIR not listed by our council) or does it just go in general waste at the tip or a skip? Would rather not just put in landfill if possible! Unfortunately it would go in landfill if you disposed of it either in your bin or at the tip. As OnOff says, also free cycle, sure there will be someone who’ll make use of it Link to comment Share on other sites More sharing options...
