Blocking a doorway
I am going to block an external doorway up. The lintel will remain above the doorway. The existing internal leaf is cinder block. Is there any disadvantage to using thermalite blocks to block the hole up? I have enough of them to do the job sat waiting to go in the skip and would have to go and buy anything else if they are unsuitable.
You can use thermal blocks
Presuming you will render over Thermalight arnt suitable for sand and cement But fine with the through coloured renders With a mesh coat
this is for internal leaf so would need scratch coat and plaster. Would that be an issue?
