bradders3109 Posted August 29, 2024 Posted August 29, 2024 Hi All, After almost four years of a very slow and painful build we are about to put a roof on, thank god. I'm using Tapco Slate Classic and according to the installation instructions these should be laid on a 50mm x 25mm batten using 30mm clout nails. Since the clout nails are longer than the batten thickness won't this result in numerous punctures to the impermeable membrane which is recommended? Am I unduly worrying or is this a specification error? I've already resolved one conflict in the installation manual whereby the tapco manual states a minimum 25mm drape for the underlay but the recommended underlay installation states a maximum of 15mm drape. Any help or advice would be much appreciated.
Dave Jones Posted August 29, 2024 Posted August 29, 2024 no, you have the width of the tile to account for as well. 1
joe90 Posted August 29, 2024 Posted August 29, 2024 Tapco's are 5mm thick and due to the slates “stacking” they will not rest flat on the batten giving 1 or 2 mm more so 30mm clouts should be ok!
bradders3109 Posted August 29, 2024 Author Posted August 29, 2024 Thanks for the responses fellas. I had thought about the tile thickness but didn't think it was 5mm. I just spoke to the technical guy at tapco and he said exactly what you have stated. Tile thickness and camber will be more than 5mm. Thanks again
