Lisa15 Posted August 24, 2024 Posted August 24, 2024 Hello  Can anyone offer any advice on pipe insulation please for flow and returns to ASHP? The majority of the pipe work is 28mm and is under the floor. I have been reading about Armacell and Kingspan pipe lagging and can’t decide on which is best or which thickness to use to ensure the pipes are as insulated as possible. Any advice would be greatly appreciated.  Many thanksÂ
JohnMo Posted August 24, 2024 Posted August 24, 2024 8 hours ago, Lisa15 said: under the floor Can you clarify what you mean by under the floor? Is in a cold space outside the insulated envelope or within the insulated envelope? Â Makes a big difference.
Lisa15 Posted August 24, 2024 Author Posted August 24, 2024 Hi John  Thanks for your reply. Apologies, I should have said, it’s in a cold space underneath the insulation.  Many thanksÂ
JohnMo Posted August 25, 2024 Posted August 25, 2024 Next thing is rodents. If say under a block and beam floor, I would armour the insulation, insert into 110mm duct and seal each end with fine stainless mesh or wire wool, expanded foamed into place. Â If it's going to get wet as above also. Â If it's underground consider doing the same. To stop the insulation being crushed. Â If it's in a basement say, just insulation will be fine. Â Then use 25mm wall thickness of what every closed cell insulation is at the best price. I used quite a bit of armacell. Prices vary hugely going into a merchant can be way cheaper than buying in there online shop. Sometimes the other way round.
Lisa15 Posted August 25, 2024 Author Posted August 25, 2024 Thank you @JohnMo it will be under a timber suspended floor, airbricks are meshed to stop any small animals getting in. Will have a shop around for some prices. Thanks for you help 😊
Lisa15 Posted August 25, 2024 Author Posted August 25, 2024 Thanks @Dave Jones will have a look at the site now. Did have a brief read about this stuff last night so good that someone else recommends. Many thanks 😊
