crispy_wafer Posted August 14, 2024 Posted August 14, 2024 Hi All, couple of quick q's, Is warmstar still the go to as far as tried and tested UFH mats is concerned please? For installing in a bathroom, onto xps board over caberdeck, how would I determine what Wattage p/m2 to go for? Tiles or LVT will be the final floor finish.
Alan Ambrose Posted August 14, 2024 Posted August 14, 2024 >>> what Wattage p/m2 to go for? Well you could just guess (I did and played it safe at 200W/m^2) - by and large it only affects the warm-up time - the thing will switch on and off to maintain the set-point temp - less switching off and more switching on for a lower wattage mat. If your bathroom is, say, 5m^2 you'll have a 1kW heating source which sounds ample. You could do a quick calc using ubakhus or similar to get the U-value above and below and the likely set-point (28C?), min below floor temperature and min air temperature above. One tip I've seen and used is to either put the themistor in a tube so it can easily be replaced or bury a spare thermistor which can be used later if the first one fails. I've done the latter before - although I can't imagine the failure rate is very high. 1
crispy_wafer Posted August 14, 2024 Author Posted August 14, 2024 Ta, i’ve put some ducting in and run a sensor to each of the bathrooms. If the time ever comes I ought be able to pull it through with a new wire attached… I only needed a couple of small mats so heating load wont be too much, and as it happens I’ve gone for a 150 in the highly insulated room, and 200 in the other one, but thats only because the vendor has run out of the 150 the mats in the m2 I wanted…
garrymartin Posted August 14, 2024 Posted August 14, 2024 7 hours ago, Alan Ambrose said: One tip I've seen and used is to either put the themistor in a tube so it can easily be replaced or bury a spare thermistor which can be used later if the first one fails. I've done the latter before - although I can't imagine the failure rate is very high. +1 They're so cheap, why wouldn't you?
