Hello everyone,
I hope someone may be able to advise me please.
A lady has asked me if I can lay 2.2m x 3.6m worth of chipboard flooring in her bungalow loft.
Im thinking there may be too much weight on the joists as its a truss roof system ?
Am I over thinking it? Possibly use loft legs instead of timbers to raise the flooring up 150mm to get over the double layer of insulation plus to save weight on the joists?
Then lay 18mm 600 x 2400mm chipboard flooring on top ?
I would really appreciate anyones time and advise.
Many thanks in advance
Depends entirely on what loading will go in to the loft. Also, definitely want stilts to avoid compressing the insulation.
Any legs will simply put the stress/weight on the existing ceiling joists anyway. What about timbers from side to side bolted to the trusses and the flooring laid on those 🤷‍♂️any weight is then on the whole structure with no point loads and stand above the  insulation.
