I have a 41 page MiTEK Industries pdf relating to the design of my first floor posi-joists.
Just wondering if someone is able to help me read the report to find the expected vertical deflection for a 50kg person walking across the floor. Or even if this value is known since only 3 load cases appeared to be considered:
Load Cases Considered: :
1 Vibration Check As EC5 NA.2.6 :
2 Long Term Floor Dead+Floor Imposed :
6 ScreedFlo Construction load Dead
Anyone a posi-joist 'expert'?
Or is there a stated acceptable floor flex anywhere?
(Sorrry I won't go into the history of why I would like to know this data)
Paul
I've been quoted very often that 12mm was acceptable - but after a while I learned that the 12mm refers to the deflection (sag) after 50 years!
Can you kindly tell me where in the BS Regs joist deflections are given, ta
