Looking at options for MVHR. Brink Fair 325 is looking promising for my needs. However the switching seems heavily biased towards using wireless switches which are rather expensive.
The unit is supplied with a single manual rotary switch but I'd like to be able to fit boost switches to bathrooms and a loo which does not have a window.
Anyone know if simple sprung rocker switches can be used with this unit?
We don't have a Brink unit, but ours uses volt free contacts for boost.  I have just used something similar to this
https://www.screwfix.com/p/british-general-900-series-10ax-1-gang-2-way-press-retractive-switch-white/21849?tc=TA5&gad_source=1&gclid=CjwKCAjw-O6zBhASEiwAOHeGxbjClTJurl32V3-e1_kTjztGco0OtS2LAYa7ZsXcrtGteX801eDE1xoCfAUQAvD_BwE&gclsrc=aw.ds
Once MVHR is up and running and the house has dried out, you don't really need to boost that much, if at all. Just let the inbuilt humidity sensor do the work. And stick one boost switch in the kitchen as a handy place to have a boost.
Edited by JohnMo
