SuperPav Posted June 24, 2024 Posted June 24, 2024 We've had a bit of a change of mind for the upstairs from carpet (original plan) to continuing the same engineered wood flooring as we have downstairs (14/3mm 600x600 versaille parquet panels with ~150mm borders). Downstairs these are getting glued onto concrete which is simple enough. Upstairs we have 22mm Egger Protect subfloors, which I'm pretty sure won't hold nails properly so I can't secret nail the engineered wood panels - can anybody confirm a suitable glue that would work directly onto Egger Protect? Unfortunately as the stairs and a few other thresholds are already in place, overboarding with ply would be a bit of a headache height wise so I'm trying to find a solution which works with the Egger Board. If absolutely not, I could overboard with 4mm ply and alter the thresholds and top stair nosing if that's the only way that would work.
Blooda Posted June 26, 2024 Posted June 26, 2024 Do a test piece in a place that does not matter or a couple offcut. Different to your position.. We needed to fix a small stud wall to the screed. So we did a trial with Adiseal Strongest Best Grab Adhesive & Sealant Sticking a foot long piece of studding to the concrete. Had to hit it with a sledge hammer to shift it, and then the timber split longitudinally. At that point we concluded it was good enough for the job. From what I remember the egger glue for the panels is expanding polyurethane glue, like gorilla glue, so not really suitable.
