JackofAll Posted June 23, 2024 Posted June 23, 2024 Anyone rendered (s&c)over cem board with any success? What primer if any did you use and did you use expandable metal? Thanks.
nod Posted June 23, 2024 Posted June 23, 2024 Yes I’ve also rendered Plasterboard Same for both Fix S Steel mesh over Fixed with S screw and washer every 300 1
JackofAll Posted June 23, 2024 Author Posted June 23, 2024 1 hour ago, nod said: Yes I’ve also rendered Plasterboard Same for both Fix S Steel mesh over Fixed with S screw and washer every 300 Thanks @nod, smooth or rough side out?
nod Posted June 23, 2024 Posted June 23, 2024 38 minutes ago, JackofAll said: Thanks @nod, smooth or rough side out? Always with the writing on show when fixed 1
