SBMS Posted June 2 Share Posted June 2 Has anyone got the u values for standard cavities for EPS beads in a cavity (eg ecobead platinum), for different cavity thicknesses? have found some numbers but most stop at around 200mm or 225m cavity. Wondered if anyone has them for 250mm, 300mm? Link to comment Share on other sites More sharing options...
JohnMo Posted June 2 Share Posted June 2 36 minutes ago, SBMS said: Has anyone got the u values for standard cavities for EPS beads in a cavity (eg ecobead platinum), for different cavity thicknesses? have found some numbers but most stop at around 200mm or 225m cavity. Wondered if anyone has them for 250mm, 300mm? Look at the value for 150mm and 200mm the difference in the values can be added to each additional 50mm or half the value for every 25mm. Link to comment Share on other sites More sharing options...
SBMS Posted June 2 Author Share Posted June 2 11 minutes ago, JohnMo said: Look at the value for 150mm and 200mm the difference in the values can be added to each additional 50mm or half the value for every 25mm. I did try that but I noticed the u value difference for cavity widths they published weren’t linear? So assumed there was more to it? Link to comment Share on other sites More sharing options...
