Nic Posted May 29, 2024 Posted May 29, 2024 Hi I see the above is one of the quieter models about anyone have any experience of this make and model at all . It’s been recommended by Green FlareÂ
JohnMo Posted May 29, 2024 Posted May 29, 2024 2 hours ago, Nic said: Hi I see the above is one of the quieter models about anyone have any experience of this make and model at all . It’s been recommended by Green Flare All I say is, have you seen the price? Not exactly the cheaper ASHP on the market.  How many dBA? And at what distance?
Nick Laslett Posted May 29, 2024 Posted May 29, 2024 If sound is your main priority this looks like an ASHP worth considering.  Spec sheet says:  Sound power level (EN 12102) = 48 dB(A)  The equivalent spec for my Panasonic WH-MDC05J3E5 is:  Sound power level (EN 12102) = 60 dB(A)  Vaillant aroTHERM plus 7kW  Sound power level (EN 12102) = 53 dB(A)  These are all at A7/W35  They seem especially pleased about the low noise and have made a video about it.   1
Nic Posted May 29, 2024 Author Posted May 29, 2024 Obviously I have know idea what the below means 😂 but it does seem like it might be over kill for my two bed house in Devon !    WPL-A 07 HK 230 Premium AIR SOURCE HEAT PUMPS PRODUCT-NO.: 200123 Create a pleasant climate all round This air source heat pump doesn't just take care of your heating and hot water. In the summer months, it can also provide cooling. And even at outside temperatures as low as minus 25 °C, it achieves high flow temperatures for pleasant room heating and high hot water convenience. This inverter appliance therefore offers you a valuable service, no matter whether you are building a new home or modernising an older one. Doing the environment a good turn The models in this series are set up to use a particularly futureproof refrigerant. Combined with an excellent efficiency level, this heat pump raises your environmental conscience in building services to a new high.  The main features Air source heat pump installed outdoors for heating and cooling Ideal for new build and modernisation Inverter technology for high efficiency and low energy bills Low noise emissions due to intelligent appliance design Operating noise can be further reduced in night mode ("silent mode") Highest energy efficiency even when using radiators Optional integration into the home network and control via smartphone (additional components required) Flow temperatures of up to 75 °C for first rate hot water convenience  Type WPL-A 07 HK 230 Premium Part no. 200123 Technical data Energy efficiency class, heat pump W35 A+++ Energy efficiency class, heat pump W55 A+++ Energy efficiency class, composite system (heat pump + controller) W35 A+++ Energy efficiency class, composite system (heat pump + controller) W55 A+++ Heating output at A7/W35 (EN 14511) 3.31 kW Heating output at A2/W35 (EN 14511) 4.30 kW Heating output at A-7/W35 (EN 14511) 6.87 kW Max. cooling capacity at A35/W7 7.30 kW Cooling capacity at A35/W18 partial load 4.94 kW Max. cooling capacity at A35/W18 10.15 kW COP at A7/W35 (EN 14511) 5.42 COP at A2/W35 (EN 14511) 4.30 COP at A-7/W35 (EN 14511) 2.93 Energy efficiency ratio at A35/W7 max. 2.35 Energy efficiency ratio at A35/W18 partial load 4.28 Energy efficiency ratio at A35/W18 max. 2.87 SCOP 35 °C (EN 14825) 4.88 Sound power level (EN 12102) 48 dB(A) Min./max. application limits for heat source -25/40 °C  Â
Nic Posted May 29, 2024 Author Posted May 29, 2024 2 minutes ago, Nick Laslett said: If sound is your main priority this looks like an ASHP worth considering.  Spec sheet says:  Sound power level (EN 12102) = 48 dB(A)  The equivalent spec for my Panasonic WH-MDC05J3E5 is:  Sound power level (EN 12102) = 60 dB(A)  Vaillant aroTHERM plus 7kW  Sound power level (EN 12102) = 53 dB(A)  These are all at A7/W35  They seem especially pleased about the low noise and have made a video about it.       sound was one of the conditions that the planners were making a fuss about . They place a condition that I need to build an acoustic barrier between us and next door ( which can't be done as the barrier would need to be on the drive ) they insist on the drive to ensure we have off street parking etc etc .   This is what they said :  Prior to first use of the air source heat pump (ASHP) hereby approved, an acoustic barrier to the front of the ASHP will be provided and constructed to the following specification: A mass of 10 kg/m2, at a height where there is no line of sight from the ASHP to the neighbouring bedroom window. It must be of solid construction with no air gaps. The acoustic barrier shall thereafter remain in perpetuity unless otherwise agreed in writing by the Local Planning Authority. (Reason: To protect adjoining residents from noise in the interests of residential amenity in accordance with Policy D1 - Design and Local Distinctiveness of the Adopted East Devon Local Plan 2013-2031.) In accordance with the requirements of Article 35 of the Town and Country Planning (Development Management Procedure) (England) Order 2015 in determining this application, East Devon District Council has worked positively with the applicant to ensure that all relevant planning concerns have been appropriately resolved.
JohnMo Posted May 29, 2024 Posted May 29, 2024 10 minutes ago, Nic said: WPL-A 07 HK 230 Premium AIR SOURCE HEAT PUMPS PRODUCT-NO.: 200123 Create a pleasant climate all round This air source heat pump doesn't just take care of your heating and hot water. In the summer months, it can also provide cooling. And even at outside temperatures as low as minus 25 °C, it achieves high flow temperatures for pleasant room heating and high hot water convenience. This inverter appliance therefore offers you a valuable service, no matter whether you are building a new home or modernising an older one. Doing the environment a good turn The models in this series are set up to use a particularly futureproof refrigerant. Combined with an excellent efficiency level, this heat pump raises your environmental conscience in building services to a new high Etc... Says nothing meaningful that doesn't really apply to most ASHP.  3 minutes ago, Nic said:     sound was one of the conditions that the planners were making a fuss about . They place a condition that I need to build an acoustic barrier between us and next door ( which can't be done as the barrier would need to be on the drive ) they insist on the drive to ensure we have off street parking etc etc .   This is what they said :  Prior to first use of the air source heat pump (ASHP) hereby approved, an acoustic barrier to the front of the ASHP will be provided and constructed to the following specification: A mass of 10 kg/m2, at a height where there is no line of sight from the ASHP to the neighbouring bedroom window. It must be of solid construction with no air gaps. The acoustic barrier shall thereafter remain in perpetuity unless otherwise agreed in writing by the Local Planning Authority. (Reason: To protect adjoining residents from noise in the interests of residential amenity in accordance with Policy D1 - Design and Local Distinctiveness of the Adopted East Devon Local Plan 2013-2031.) In accordance with the requirements of Article 35 of the Town and Country Planning (Development Management Procedure) (England) Order 2015 in determining this application, East Devon District Council has worked positively with the applicant to ensure that all relevant planning concerns have been appropriately resolved. They don't really care if it's silent or the most noisy available - the same condition applies.  1
Nic Posted May 29, 2024 Author Posted May 29, 2024 5 minutes ago, JohnMo said: Says nothing meaningful that doesn't really apply to most ASHP. Â They don't really care if it's silent or the most noisy available - the same condition applies. Â Â Â John you are probably rightÂ
