WiltshireLink Posted May 12, 2024 Posted May 12, 2024 Hi, don't suppose anyone has some spare Nudura 6" end caps I could buy? Need some extra but not a whole box worth. Cheers
WiltshireLink Posted May 16, 2024 Author Posted May 16, 2024 On 13/05/2024 at 21:35, FM2015 said: Cut up your waste if you've got any Ideally want some end caps but good ideaÂ
BotusBuild Posted May 16, 2024 Posted May 16, 2024 Do you mean buck ends? I ran out but had spare standard blocks left over, which I cut up. Set the blade depth on a circular saw to cut the notches in the sides. Bit messy, but does the job - Wear a mask and goggles 🙂 1
FM2015 Posted May 17, 2024 Posted May 17, 2024 On 16/05/2024 at 12:09, WiltshireLink said: Ideally want some end caps but good idea Offcuts, foam and builders band work perfectly. You don't need the dovetails. Timber can also be used to brace/hold them in place. 1
