WiltshireLink Posted May 12, 2024 Posted May 12, 2024 Hi, don't suppose anyone has some spare Nudura 6" end caps I could buy? Need some extra but not a whole box worth. Cheers
WiltshireLink Posted May 16, 2024 Author Posted May 16, 2024 On 13/05/2024 at 20:35, FM2015 said: Cut up your waste if you've got any Expand Ideally want some end caps but good idea
BotusBuild Posted May 16, 2024 Posted May 16, 2024 Do you mean buck ends? I ran out but had spare standard blocks left over, which I cut up. Set the blade depth on a circular saw to cut the notches in the sides. Bit messy, but does the job - Wear a mask and goggles 🙂 1
FM2015 Posted May 17, 2024 Posted May 17, 2024 On 16/05/2024 at 11:09, WiltshireLink said: Ideally want some end caps but good idea Expand Offcuts, foam and builders band work perfectly. You don't need the dovetails. Timber can also be used to brace/hold them in place. 1
