spleenharvester Posted May 4, 2024 Share Posted May 4, 2024 Hi all I want to remove a wall from my outhouse. In the attached diagram it's the red one. The outhouse is solid brick construction in the walls, not sure what the roof is made from. Do you reckon I can safely knock this wall through or does it need support beams? The dream would be to knock all the inner walls through but I assume that would definitely need support beams? All input appreciated! Link to comment Share on other sites More sharing options...
stu w Posted May 4, 2024 Share Posted May 4, 2024 Impossible to tell from those pictures and description. Get a professional to advice you after looking at all the variables once a site visit has been done Link to comment Share on other sites More sharing options...
spleenharvester Posted May 4, 2024 Author Share Posted May 4, 2024 9 minutes ago, stu w said: Impossible to tell from those pictures and description. Get a professional to advice you after looking at all the variables once a site visit has been done Sure, thought it was worth a try. Thank you anyway! Link to comment Share on other sites More sharing options...
joe90 Posted May 4, 2024 Share Posted May 4, 2024 From those pics I would guess the roof is concrete, so heavy, and depends if there is a join in them over the wall. Is there a span which does not have a wall (apart from the two ends?) Link to comment Share on other sites More sharing options...
markc Posted May 4, 2024 Share Posted May 4, 2024 Pretty typical ex council house outhouse, concrete slab roofs were lifted on in one piece usually. Good concrete little reinforcing. Will happily self support over a single doorway but would need support for a double door size opening. Link to comment Share on other sites More sharing options...
