Shallow dug ducting for mains water
Barny
Hi.
Does anyone know of water board approved ducting for water pipes where you can’t get to the required depth?
I have found some products on line but not sure which are sufficient.
we can only go circa 450mm deep as we are crossing a culvert.
Thanks
48 minutes ago, Barny said:
Hi.
Thanks
They may require you go underneath then depending who is signing it off
Agree with the above, going over a) reduces depth so increases risk of freezing and b) gives an additional cold spot from the culvert itself. Bit of extra digging and get it under.
