scottishjohn Posted October 29, 2024 Posted October 29, 2024 11 hours ago, Redbeard said: Free-standing stud wall with insulation and adequate x-vent behind is great, and ventilation may be adequate for a whole elevation with say 4 air-bricks per storey. If you have studs against the wall then you need an 'in' and an 'out' (say 225 x 150 each) between *each pair of studs'. That's a hell of a lot of air-bricks, ranging from 'not aesthetically pleasing' on, say, brick walls to virtually impossible of rubble-filled stone with a loose core. https://assets.publishing.service.gov.uk/media/614b30aad3bf7f718a54c0be/iwi-guidance.pdf you do not need air bricks ,and air bricks should be ducted through both walls to under side of house to vent under the suspended floors ,not just in outer layer to make a draft up the cavity just let it happen naturally --warm air rises and so takes moisture with it and we are talking about an old house which we want to dry out or keep it dry at back of wall as for fire risk you fit intumescent fire stops which only expand if there is a fire and blocks off the cavity as for getting condensation on VCL--thats shows your insulation is not good enough and or lots of air leaks through it -if correct the insulation should stop any chance of condensation assuming you are not hydroponically growing weed inside
scottishjohn Posted October 29, 2024 Posted October 29, 2024 4 hours ago, Annker said: One issue I dont have is moisture passing through the walls from outside. The brickwork is the house bone dry, you cannot imagine how dry. If I handle the bricks (I've knocked through many openings) for a day the skin on my hands opens up, the bricks literally pull the oil from them and we're not talking office boy hands here either 😂 that will be internal walls which are dried from both sides from heat in house for 100years the outer walls are different as one side can be wet +cold and other heated by internals of house and thats where you will get condensation if the dew point is reached kile the inside of a single glazed window on a cold morning. I doubt you will have any DPC in a victorian house so thats the other place capillary action from water in the ground sucks it up which is why we have a DPC to stop it happening and why with no DPC it pays to have ground level outside house a lot lower than floor l there was reason why expnsive big old houses had steps up to entrance level, even if they did not have cellars to keep floor joists etc well above any rising damp from the foundations as genaral rule rising damp will only go up to a metre maximum on modern house with concrete floors etc the floor level will always be at least 150mm minimum above the ground level outside if not then lots of french drains and pea gravel to soak away any water from the walls look at the detail for dpc under a slab and where it finishs inside the walls above the floor level into the walls usually where the outer wall DPC is and your TF kit starts on dwarf walls
