ukcat Posted April 18, 2024 Share Posted April 18, 2024 I'm just about to start bricking up to create new enclosure for inset stove pic shows roughly where bricks will be and trowel is were stove will eventually be positioned. The base is concrete but needs raising up by about 30mm which I planned to screed with grit sand and cement. Question is should I brick up and then apply the screed or screed the whole area and build onto the screed. Thanks in advance Link to comment Share on other sites More sharing options...
Russell griffiths Posted April 18, 2024 Share Posted April 18, 2024 That looks like a small space, have you read the clearance regs for the stove your buying. brickwork first screed second. imho. Link to comment Share on other sites More sharing options...
ukcat Posted April 18, 2024 Author Share Posted April 18, 2024 27 minutes ago, Russell griffiths said: That looks like a small space, have you read the clearance regs for the stove your buying. brickwork first screed second. imho. Hi thanks for the reply. Bricks are just dropped in to give the general idea. Yes current opening is 850mm but this will reduce down to 470mm which will give 10mm clearance around the stove (it's an inset type) Link to comment Share on other sites More sharing options...
