Which (if any) fixings hold PIR and Plasterboard to blockwork?
Morning all,
I am providing myself with a tiny little garden office, the walls are built of single skin heavy block.
I plan to add 100mm PIR insulation inside the blockwork, then finish with plasterboard (or maybe ply sheets).
There are a number of mechanical fixings I could use to pin the PIR to the walls internally, but the question is, how best to fix the plasterboard or ply in place?
I had thought to fix 100mm timber batons to the wall, but that will, of course, create a cold bridge.
Is anyone aware of a fixing solution they would recommend?
Cheers!
Garden Office Details (1).pdf
Normally you would put a service void between plasterboard and PIR for cables, sockets / plumbing etc.  so screw through battens & PIR into blockwork.   7mm dia concrete screws are fairly inexpensive in longer lengths and you only need to drill a hole as they are self tapping.
Edited by Jenki
url added
I had totally forgotten the service void!
Thanks very much.
