Some of you may remember the cock up of a cemfloor that I had pumped in last year with dips and cracks etc.
Well now the time to get it flat is coming near and I need to start thinking about getting it flat prior to tiling and wood flooring.
I have a couple of areas ( around 5m2) that are about 15 mm low and a  bump in the middle ( around 3 m2) that is around 10 mm high. In addition to this the whole surface has stones sticking up around 2 - 3 mm above the flat surface of the concrete.
I intend to use a decoupling membrane under the tiling and an approved underlay under the engineered oak flooring.
My questions are :-
What machine have you guys used to grind the floors down ? Will I do it in a day ( 85 m2) ? I’d like to use a window of opportunity given to me by a delay in my plasterers returning.
Would it be ok to level the floor using levelling compound between the raised aggregates after removing the high spots or should I try to grind them out ?5E9B9A9B-74D5-4CE9-A062-07B689586CDC.thumb.jpeg.32318586492330809cc47a23f408b6b8.jpeg
I’ve a couple of these machines and we use them on a weekly basis Mine are both aitechs But speedy to two different ones Get the larger Get it all marked out prior to hire and you will easily do 85m2 in a day
Don’t forget to hire a 30 amp transformer and lead
Thanks Nod I have the transformer and leads. I was planning on setting the laser up and dipping the whole floor prior to the battle to highlight the high spots. What do you think about the raised aggregates ?
Raised aggregates look great
But are difficult to repair if damaged
