Wobbly toilet seat
AdamD
  • 3 weeks later...
On 01/04/2024 at 09:24, dpmiller said:
push down harder until it clicks locked?
Not possible, done that when I installed it. Won’t go any further. All lines up with the seat holes. I’m perplexed!
8 minutes ago, dpmiller said:
yes, but do you need to use the button to release it or will it pull straight off?
Pulls straight off without touching the button, which obviously makes it unable when using etc as somehow it isn’t fixed in. But I’ve taken it out and properly pushed it down and clicked it a few times, but still just lifts off without the button.
Maybe faulty, just seems odd and something that should be so simple
it really seems like it's not going down far enough. Sometimes the little "rings" on the posts are hard to compress the first time round and can take a wipe of lubricant and quite a bit of force to get them started. Try also pressing the button in whilst pushing down.
/stupid Q- you haven't fitted multiple different seats and managed to swap the fittings over?
