j_s Posted March 9, 2024 Share Posted March 9, 2024 Hi guys Might be a silly question, can I use a heat pump unvented cylinder with a gas boiler? Was thinking about being heat pump ready in the future. Was looking at Newark Cylinders. Thanks James Link to comment Share on other sites More sharing options...
JohnMo Posted March 9, 2024 Share Posted March 9, 2024 14 minutes ago, j_s said: Hi guys Might be a silly question, can I use a heat pump unvented cylinder with a gas boiler? Was thinking about being heat pump ready in the future. Was looking at Newark Cylinders. Thanks James Yes the only difference is the coil size, it's way bigger, so you excellent heat transfer. You could flow at low temps heat to 48-50, get very little heat loss at the same time. If you are future proofing make sure you size for a typical heat pump i.e. how many litres it holds, will be bigger than a normal gas boiler cylinder. 1 Link to comment Share on other sites More sharing options...
j_s Posted March 9, 2024 Author Share Posted March 9, 2024 (edited) I'm planning on a 210l cylinder which matches up with the chart exactly, got 2 bathrooms and 4 bedrooms but 3 of us in the house. Thank you 🙂 Edited March 9, 2024 by j_s Link to comment Share on other sites More sharing options...
JohnMo Posted March 9, 2024 Share Posted March 9, 2024 We have the same, two of in the house, never ran out of water. 1 Link to comment Share on other sites More sharing options...
