March 5, 20242 yr Hi, would anyone be able to advise if reclaimed pine boards can be used in a loft conversion please? Checking from the angle of building regs (hence my posting here) but also interested in opinion. 'Tongue and groove high density board' has been quoted for. Thanks, Will
March 5, 20242 yr No reason you can’t use reclaimed boards, but they are a pain to clean up, loads of holes, splits and cracks and they are a pain and time consuming (and therefore costly) to lay. if you want a wood look, use chipboard and put laminate over the top.
