MoDo Posted February 15, 2024 Posted February 15, 2024 (edited) Thanks @Bramco. Might look into Cool Energy then as the £7.5k grant is quite a disincentive to self-install if it cannot be claimed (with a self-install). My understanding is the grant is only available with an MCS approved install. Seems there is a firm that will do the MCS paperwork for a self-install for about £1.5k so that could be an alternative option. Edited February 15, 2024 by MoDo
Bramco Posted February 15, 2024 Posted February 15, 2024 On 15/02/2024 at 09:23, MoDo said: Seems there is a firm that will do the MCS paperwork for a self-install for about £1.5k Expand @MoDo That seems lower than the uplifts I seemed to be getting on quotes, although it's hard to work out from a quote. Maybe a way forward. Wonder if there's someone that would do the MCS for a battery install - a lot simpler as there's no heat loss calcs. Can you share the name of the folks that would do it for an ASHP? Simon
MoDo Posted February 15, 2024 Posted February 15, 2024 I saw it here (another thread). The website linked to is https://www.unitherm.co.uk/pages/mcs-design Downside is the £1.5k only gets you the grant, no physical installation work. Though as you say, it seems majority if not all MCS installers are whacking on significantly more than £1.5k with grant funded installations.
Gordo Posted November 19, 2024 Posted November 19, 2024 On 01/02/2024 at 16:10, HughF said: I’ve got the 1m2 vaillant cylinder… 9kW heat pump with a pwm pump driving into it. Works perfectly and recovers fast. Expand do you mean a 1m2 primary heating coil? with a pump to increase the flow through coil? what l/m pump did you decide on
