machtucker Posted January 28, 2024 Posted January 28, 2024 Hi! I'm having some cedar battens delivered tomorrow and will be starting to make the panels shortly. I have an Evolution 255DB+ compound mitre saw which has worked well for me so far. I currently have multipurpose blade that came with the saw on it. Do you think I should buy a fine wood cutting blade like this? https://shop.evolutionpowertools.com/collections/evolution-blades/products/255mm-fine-wood-blade-60t Seems fairly pricey. I'm setting up a stop block which should aid the cutting process. Any guidance/comments welcome. Many thanks, E
Conor Posted January 28, 2024 Posted January 28, 2024 You'll get an equivalent blade from Amazon for about £20. I use trend and Saxton. https://amzn.eu/d/aZRIIIG 1 1
oliwoodings Posted January 28, 2024 Posted January 28, 2024 +1 to trend's high tooth fine blades. Got one for doing kitchen panels, perfect cuts with no tear out. 1
machtucker Posted February 28, 2024 Author Posted February 28, 2024 Went with the Saxton blade and it’s very good. Lovely cuts so far.
