Asking for a friend whose oil boiler has packed up. She has been quoted £10k and that sounds crazy to me.
anyone have a reasonable idea?
it’s an external one at the moment that works with a hot water tank if that makes a difference but not sure of actual size. Apparently it will involve changing rads to thermostatic valves at the same time.
I'm not sure if there are regulations that require you to do more than just replace the boiler.
Grant still make External oil boilers. Price of the boiler alone on the Internet appears to r £1800 to $3500 is depending on size.
She should get several quotes.
