IJM01 Posted January 26, 2024 Posted January 26, 2024 Hi Yorkshire water insist they cant provide me a quote without VAT. Is this correct? if so, can i reclaim it? thanks
nod Posted January 26, 2024 Posted January 26, 2024 Get the quote Then provide proof of your zero treated status As you can’t reclaim afterwards
Temp Posted January 26, 2024 Posted January 26, 2024 (edited) +1 Assuming this is a qualifying building like a new house.. Must be zero rated to you. You cannot reclaim it (Or any other VAT paid in error). Refer the water Co to VAT 708.. https://www.gov.uk/guidance/buildings-and-construction-vat-notice-708 Specifically.. Quote 3.1.2 The basic conditions Your services can be zero-rated when all of the following conditions are met: 1) A qualifying building has been, is being or will be constructed (read paragraph 3.2 and section 14). 2)Your services are made ‘in the course of the construction’ of that building (read paragraph 3.3). 3) Where necessary, you hold a valid certificate (read section 17). 4) Your services are not specifically excluded from zero rating (read paragraph 3.4). Snip 3.3 Services made ‘in the course of the construction’ of the building Snip 3.3.4 Work closely connected to the construction of the building Subject to paragraph 3.3.6, your work is closely connected to the construction of the building when it either: Snip (b) produces works that allow the building to be used, such as works in connection with the: * means of providing water and power to the building (this can extend to the work required to make the connection to the nearest existing supply) continues. Edited January 26, 2024 by Temp
