westcoast Posted January 23, 2024 Posted January 23, 2024 (edited) Annoyingly after final floors went down (microcement) we noticed shower drain rocking and subsequent cracking of microcement.  turns out linear drain wasn’t seated correctly into mortar by plumber - 5mm gap under ‘wing’ of drain.  Gap fixed now with epoxy.   You can see I removed a lot of screed cement during my investigation:   should I repair this with concrete or sand+cement? in any case I’m thinking of using some steel dowels to connect all the elements.  its about 100mm deep but only 15mm deep over pipe! Edited January 23, 2024 by westcoast
Mr Punter Posted January 23, 2024 Posted January 23, 2024 Christ what a mess! Â I can't see how that could be patched in, but I have zero experience with laying microcement.
Conor Posted January 23, 2024 Posted January 23, 2024 Is this the finished shower surface? How are you going to waterproof the patch? You'll have to use something that won't shrink.Â
westcoast Posted January 23, 2024 Author Posted January 23, 2024 (edited) Microcement people are coming back to sand down whole tray and re apply microcement so waterproofing is not an issue  im just wondering if I should pour concrete in the hole for strength or match the screed material (sand and cement) Edited January 23, 2024 by westcoast
Conor Posted January 23, 2024 Posted January 23, 2024 I'd use concrete with small stones, just because it's cheaper and faster. I'm sure you've some insualtion to slot in first then foam in to place. 1
