Amelia Winters Posted January 15, 2024 Share Posted January 15, 2024 Hi everyone, just saying hello - I'm Amelia, or Amy is fine I decided in September I'd give building a garden room a go. So far, so good. Walls are up and the roof is on..ish. Waiting for it to warm up a bit before I try and fit the rubber roof.. damn water based adhesives! I'll be probably asking some questions about plasterboard and insulation really. Got most of the other stuff nailed down - even managed to fit the door and window myself without making too much of a mess of it all. Hope to draw on some of your helpful selves soon :) Amy Link to comment Share on other sites More sharing options...
JohnMo Posted January 15, 2024 Share Posted January 15, 2024 Hi 8 minutes ago, Amelia Winters said: decided in September I'd give building a garden room a go. So far, so good Is it a log cabin type of garden room, with inter locking wooden blocks to build the walls? Link to comment Share on other sites More sharing options...
Amelia Winters Posted January 15, 2024 Author Share Posted January 15, 2024 (edited) 2 minutes ago, JohnMo said: Hi Is it a log cabin type of garden room, with inter locking wooden blocks to build the walls? Hey! No, timber frame construction, OSB3 sheeting walls / roof, 18mm marine ply on a ground screw/frame foundation Edited January 15, 2024 by Amelia Winters Link to comment Share on other sites More sharing options...
Alan Ambrose Posted January 16, 2024 Share Posted January 16, 2024 Well congrats. If you can get the roof edges to drain properly so that any ground splash won’t soak the lower 6 inches of walls, that’ll give it a long life. I was not convinced about the pva stuff, did they supply contact adhesive for the edges? Probably not a big deal anyway as it’ll lie flat (ish). There are some good stainless nails with rubber collars to hold down the edges of the epdm - you probably don’t need many. I also used ss staples in the non-critical parts. Link to comment Share on other sites More sharing options...
Amelia Winters Posted January 16, 2024 Author Share Posted January 16, 2024 Thanks - it's proving a little more difficult than I first thought but getting there! Yeah there's WBA for the main deck and contact adhesive for the perimeter of it, 100mm worth if I remember right - got some kerb edge trim which will hopefully keep most from running down the fascia but opted for a layer of gravel around the base to try and reduce the splash back a little from it Link to comment Share on other sites More sharing options...
