Allex Posted January 15, 2024 Posted January 15, 2024 I have found one with the flashing for tiles (up to 13mm) but my tiles are Marley modern (30mm) thick. Will I be able to make the flashing fit the thicker tiles say by lifting the window a bit?
SuperPav Posted January 15, 2024 Posted January 15, 2024 Probably not depending on which flashing you have (the flexi-bendy ones with straight sides are a bit more flexible in terms of installation), but you can usually adapt virtually any velux flashing kit by making your own flashings/soakers out of lead as required. What I will say though, is that's unlikely to be much (or at all) cheaper than just getting a replacement correct flashing kit from Velux...
