I’m looking at installing a secondary circulating pump. The ‘go-to’ seem to be Grundfos comfort or these:
https://www.anchorpumps.com/lowara-ecocirc-pro-15-1-65br-1-2-bronze-circulator-with-temp-control-240v
I cannot for the life of me figure out the fittings needed to take this down to 15mm copper. Ideally I also want to put 1/4 lever valves either side for easy maintenance.
These HRC pumps seem to have either 1/2” female parallel or 1-1/4” male parallel ports.
What fitting would I need to drop either of those to 15mm copper?
These look perfect
https://www.toolstation.com/perfect-pump-valves/p52920
but I’m pretty sure are 1-1/2 on the pump side (normal size for main circulator?)
No apparent equivalent for 1-1/4 port
Edited by OwenF
  • OwenF changed the title to Secondary HW pump connection/fittings
Great, thanks. It was your posts that led me to the Lowara pump.
I can see a lot of adaptors between the pump and the copper. Any chance you can recall what each is?
Looks like:
pump
1/2” male to ? female coupler
NRV (1/2 to 1/2?)
1/2” female to 15mm compression bend
copper
the one out of sight looks simpler
My understanding is the 1/2” male into the pump has to be taper, or if parallel needs to be a union with washers.
Looks like:
pump
NRV (1/2 to 1/2?)
copper
I know a bunch of fittings came with the pump, including nrv. But cannot recall exactly what. I would wait until you get the pump and go from there. They change design all the time,
